Differences
bbob-2015 [2015/06/09 16:39]
brockho
bbob-2015 [2015/06/09 16:40] (current)
brockho [Black-Box Optimization Benchmarking (BBOB) 2015]
Line 75: Line 75:
    * 04/20: acceptance notification    * 04/20: acceptance notification
    * 05/04: final paper version due    * 05/04: final paper version due
-   * 07/11 or 07/12: workshop at [[http://www.sigevo.org/gecco-2015|GECCO]]+   * 07/12: workshop at [[http://www.sigevo.org/gecco-2015|GECCO]]
 In order to prepare linking an optimizer to the BBOB-framework code and running first tests, the currently available [[http://coco.gforge.inria.fr/doku.php?id=downloads|downloads]] can be used. The code for the final experiment and post-processing obey the very same interface are released soon (see above).  In order to prepare linking an optimizer to the BBOB-framework code and running first tests, the currently available [[http://coco.gforge.inria.fr/doku.php?id=downloads|downloads]] can be used. The code for the final experiment and post-processing obey the very same interface are released soon (see above).
bbob-2015.txt · Last modified: 2015/06/09 16:40 by brockho
CC Attribution-Noncommercial-Share Alike 3.0 Unported
Valid CSS Driven by DokuWiki Recent changes RSS feed Valid XHTML 1.0
