Differences
higlighted_results_all_functions [2011/10/28 15:14]
vhm
higlighted_results_all_functions [2011/11/03 11:38] (current)
vhm
Line 3: Line 3:
-Empirical runtime distributions (runtime in number of function evaluations divided by dimension) on all functions with target values in {100, ... , 10e-8} in dimension 10. The cross indicates the maximum number of function evaluations. A decline in steepness right after the cross (e.g. for IPOP-SEP-CMA-ES) indicates that the maximum number of function evaluations should have been chosen larger. A steep increase right after the cross (e.g. for simple GA) indicates that a restart should have been invoked earlier.+Empirical runtime distributions (runtime in number of function evaluations divided by dimension) on all functions with target values in {100, ... , 1e-8} in dimension 10. The cross indicates the maximum number of function evaluations. A decline in steepness right after the cross (e.g. for IPOP-SEP-CMA-ES) indicates that the maximum number of function evaluations should have been chosen larger. A steep increase right after the cross (e.g. for simple GA) indicates that a restart should have been invoked earlier.
higlighted_results_all_functions.txt · Last modified: 2011/11/03 11:38 by vhm
CC Attribution-Noncommercial-Share Alike 3.0 Unported
Valid CSS Driven by DokuWiki Recent changes RSS feed Valid XHTML 1.0
