Differences
mo-gecco2015 [2016/04/07 15:53]
brockho [Multiobjective Blackbox Optimization Benchmarking]
mo-gecco2015 [2016/04/07 15:53] (current)
Line 3: Line 3:
 This is the supplementary material web page related to the GECCO-2015 paper by Brockhoff, Tran, and Hansen [1]. Below, you will find the source code to reproduce the results of the paper as well as many plots which had to be omitted from the paper due to space limitations. This is the supplementary material web page related to the GECCO-2015 paper by Brockhoff, Tran, and Hansen [1]. Below, you will find the source code to reproduce the results of the paper as well as many plots which had to be omitted from the paper due to space limitations.
-Note that in the meantime, the code has evolved into the new version of the [[https://github.com/numbbo/coco|COCO platform]]).+Note that in the meantime, the code has evolved into the new version of the [[https://github.com/numbbo/coco|COCO platform]].
 ===== Source Code ===== ===== Source Code =====
 <html> <html>
mo-gecco2015.txt · Last modified: 2016/04/07 15:53 by brockho
CC Attribution-Noncommercial-Share Alike 3.0 Unported
Valid CSS Driven by DokuWiki Recent changes RSS feed Valid XHTML 1.0
