Differences
algorithms [2017/05/15 11:52]
brockho
algorithms [2020/06/02 16:28] (current)
brockho added link to bbob-largescale data
Line 1: Line 1:
-The following table lists all algorithms related to the BBOB workshops and special sessions in the years 2009 till 2015 together with links to their data. In order to sort the table according to some columnsplease click on the corresponding table header. If available, the source codes of the algorithms can be downloaded by clicking on the link with the corresponding algorithm name in the second column+With the COCO platform, we aim (amongst other goals) at reproducible benchmarking results. To this end, we collect and provide many algorithm data sets for the different COCO test suites here on this web page.
 +Through the links below, you can find all COCO algorithm data sets, supported by the COCO/BBOB teamtogether with the corresponding research papers describing the results as well as the source code of the algorithms if available.
 +====== bbob ======
 +The ''bbob'' test suite consists of 24 noiseless, single-objective functions without explicit constraints (some functions can be considered as bound-constrained).
 +[[http://coco.gforge.inria.fr/doku.php?id=algorithms-bbob|Algorithm Data Base for bbob]]
 +====== bbob-noisy ======
 +The ''bbob-noisy'' test suite consists of 30 single-objective functions without explicit constraints that are composed of a subset of the ''bbob'' functions with additional noise.
 +[[http://coco.gforge.inria.fr/doku.php?id=algorithms-bbob-noisy|Algorithm Data Base for bbob-noisy]]
 +====== bbob-biobj ======
 +The ''bbob-biobj'' test suite is the first supported multiobjective suite with 55 noiseless, bi-objective functions without explicit constraints (some functions can be considered as bound-constrained) that are based on the combination of 10 selected ''bbob'' test functions.
 +[[http://coco.gforge.inria.fr/doku.php?id=algorithms-bbob-biobj|Algorithm Data Base for bbob-biobj]]
 +====== bbob-largescale ======
 +The ''bbob-laregscale'' test suite consists of the 24 noiseless, single-objective `bbob` functions, extended towards dimensions 20-640.
 +[[http://coco.gforge.inria.fr/doku.php?id=algorithms-bbob-largescale|Algorithm Data Base for bbob-largescale]]
-<sortable>
-^No^Algorithm^Year^Author(s)^Data Noiseless^Data Noisy^related PDFs and Remarks^
-|1|ALPS|2009|Hornby|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/ALPS_hornby_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/ALPS_hornby_noisy.tgz|noisyData]]|[[http://coco.gforge.inria.fr/lib/exe/fetch.php?media=pdf2009:hornby-alps.pdf|PDF]]|
-|2|AMALGAM|2009|Bosman et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/AMALGAM_bosman_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/AMALGAM_bosman_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2247-bosman.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2351-bosman.pdf|PDFnoisy]]|
-|3|BAYEDA|2009|Gallagher|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/BAYEDA_gallagher_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/BAYEDA_gallagher_noisy.tgz|noisyData]]|[[http://staff.itee.uq.edu.au/marcusg/papers/wk2008-gallagher.pdf|PDFnoiseless]] [[http://staff.itee.uq.edu.au/marcusg/papers/wk2022-gallagher.pdf|PDFnoisy]]|
-|4|BFGS|2009|Ros|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/BFGS_ros_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/BFGS_ros_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2409-ros.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2415-ros.pdf|PDFnoisy]]|
-|5|BIPOP-CMA-ES|2009|Hansen|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/BIPOP-CMA-ES_hansen_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/BIPOP-CMA-ES_hansen_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2389-hansen.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2397-hansen.pdf|PDFnoisy]]|
-|6|Cauchy-EDA|2009|Pošík|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/Cauchy-EDA_posik_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2309-posik.pdf|PDF]]|
-|7|CMA-ESPLUSSEL|2009|Auger and Hansen|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/CMA-ESPLUSSEL_auger_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/CMA-ESPLUSSEL_auger_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2459-auger.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2467-auger.pdf|PDFnoisy]]|
-|8|DASA|2009|Korošec and Šilc|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/DASA_korosec_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/DASA_korosec_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2295-korosec.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2375-korosec.pdf|PDFnoisy]]|
-|9|DE-PSO|2009|García-Nieto et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/DE-PSO_garcia-nieto_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/DE-PSO_garcia-nieto_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2231-garcia-nieto.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2343-garcia-nieto.pdf|PDFnoisy]]|
-|10|DIRECT|2009|Pošík|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/DIRECT_posik_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2315-posik.pdf|PDF]]\\ algorithm is deterministic and thus, only run on each instance once |
-|11|EDA-PSO|2009|El-Abd and Kamel|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/EDA-PSO_el-abd_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/EDA-PSO_el-abd_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2263-elabd.pdf|PDF]]|
-|12|FULLNEWUOA|2009|Ros|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/FULLNEWUOA_ros_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/FULLNEWUOA_ros_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2421-ros.pdf|original 2009 noiseless paper]]\\ [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2429-ros.pdf|original 2009 noisy paper]]\\ [[https://hal.inria.fr/inria-00473774/document|2010 comparison noiseless]]\\ [[https://hal.inria.fr/inria-00473776/document|2010 comparison noisy]]|
-|13|G3PCX|2009|Pošík|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/G3PCX_posik_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2321-posik.pdf|PDF]]|
-|14|GA|2009|Nicolau|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/GA_nicolau_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2473-nicolau.pdf|PDF]]|
-|15|GLOBAL|2009|Pál et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/GLOBAL_pal_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/GLOBAL_pal_noisy.tgz|noisyData]]|BBOB-2009 paper not available online\\ [[http://www.mat.univie.ac.at/~neum/ms/pal.pdf|corresponding ECJ Paper]]|
-|16|iAMALGAM|2009|Bosman et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/iAMALGAM_bosman_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/iAMALGAM_bosman_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2247-bosman.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2351-bosman.pdf|PDFnoisy]]|
-|17|IPOP-SEP-CMA-ES|2009|Ros|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/IPOP-SEP-CMA-ES_ros_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/IPOP-SEP-CMA-ES_ros_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2435-ros.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2441-ros.pdf|PDFnoisy]]|
-|18|LSfminbnd|2009|Pošík|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/LSfminbnd_posik_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2329-posik.pdf|PDF]]|
-|19|LSstep|2009|Pošík|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/LSstep_posik_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2329-posik.pdf|PDF]]|
-|20|MA-LS-CHAIN|2009|Molina et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/MA-LS-CHAIN_molina_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/MA-LS-CHAIN_molina_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2255-molina.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2359-molina.pdf|PDFnoisy]]|
-|21|MCS|2009|Huyer and Neumaier|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/MCS_huyer_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/MCS_huyer_noisy.tgz|noisyData]]|[[http://www.mat.univie.ac.at/~neum/ms/mcs_exact.pdf|PDFNoiseless]] [[http://www.mat.univie.ac.at/~neum/ms/mcs_noisy.pdf|PDFnoisy]]|
-|22|NELDERDOERR|2009|Doerr et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/NELDERDOERR_doerr_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2239-doerr.pdf|PDF]]|
-|23|NELDER|2009|Hansen|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/NELDER_hansen_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2403-hansen.pdf|PDF]]|
-|24|NEWUOA|2009|Ros|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/NEWUOA_ros_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2421-ros.pdf|original 2009 noiseless paper]]\\ [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2429-ros.pdf|original 2009 noisy paper]]\\ [[https://hal.inria.fr/inria-00473779/document|2010 comparison with BIPOP-CMA-ES noiseless]]\\ [[https://hal.inria.fr/inria-00473774/document|2010 comparison noiseless]]\\ [[https://hal.inria.fr/inria-00473776/document|2010 comparison noisy]]\\ noisy data under #59 (2010)|
-|25|ONEFIFTH|2009|Auger|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/ONEFIFTH_auger_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/ONEFIFTH_auger_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2447-auger.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2453-auger.pdf|PDFnoisy]]|
-|26|POEMS|2009|Kubalík|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/POEMS_kubalik_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2303-kubalik.pdf|PDF]]|
-|27|PSO|2009|El-Abd and Kamel|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/PSO_el-abd_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/PSO_el-abd_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2269-elabd.pdf|PDF]]|
-|28|PSO_Bounds|2009|El-Abd and Kamel|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/PSO_Bounds_el-abd_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/PSO_Bounds_el-abd_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2275-elabd.pdf|PDF]]|
-|29|RANDOMSEARCH|2009|Auger and Ros|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/RANDOMSEARCH_auger_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/RANDOMSEARCH_auger_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2479-auger.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2485-auger.pdf|PDFnoisy]]|
-|30|Rosenbrock|2009|Pošík|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/Rosenbrock_posik_noiseless.tgz|noiselessData]]|n/a|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2337-posik.pdf|PDF]]|
-|31|SNOBFIT|2009|Huyer and Neumaier|n/a|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/SNOBFIT_huyer_noisy.tgz|noisyData]]|[[http://www.mat.univie.ac.at/~neum/ms/snobfit_noisy.pdf|PDFNoisy]]|
-|32|VNS|2009|García-Martínez and Lozano|[[http://coco.gforge.inria.fr/data-archive/bbob/2009/VNS_garcia-martinez_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2009/VNS_garcia-martinez_noisy.tgz|noisyData]]|[[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2287-garcia-martinez.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/sites/default/files/files/TematicWebSites/EAMHCO/contributionsGECCO09/p2367-garcia-martinez.pdf|PDFnoisy]]|
-|33|1komma2|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1komma2_brockhoff_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/1komma2_brockhoff_noisy.tar.gz|noisyData]]|[[https://hal.inria.fr/inria-00502435|cmp1komma2mirAnd1komma2mirser]] [[http://dx.doi.org/10.1145/1830761.1830772|doi]]\\ [[http://sci2s.ugr.es/eamhco/pdfs/contributionsGECCO10/p1575-auger.pdf|cmp1komma2mirAnd1komma2mirserNoisy]] [[https://hal.inria.fr/inria-00502431/document|cmp1komma2ser]] [[https://hal.inria.fr/inria-00502432/document|cmp1komma2serNoisy]]|
-|34|1komma2mir|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1komma2mir_brockhoff_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/1komma2mir_brockhoff_noisy.tar.gz|noisyData]]|[[https://hal.inria.fr/inria-00502435|cmp1komma2And1komma2mirser]] [[http://dx.doi.org/10.1145/1830761.1830772|doi]]\\ [[http://sci2s.ugr.es/eamhco/pdfs/contributionsGECCO10/p1575-auger.pdf|cmp1komma2And1komma2mirserNoisy]]|\\
-|35|1komma2mirser|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1komma2mirser_brockhoff_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/1komma2mirser_brockhoff_noisy.tar.gz|noisyData]]|[[https://hal.inria.fr/inria-00502435|cmp1komma2And1komma2mir]] [[http://dx.doi.org/10.1145/1830761.1830772|doi]]\\ [[http://sci2s.ugr.es/eamhco/pdfs/contributionsGECCO10/p1575-auger.pdf|cmp1komma2And1komma2mirNoisy]]|
-|36|1komma2ser|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1komma2ser_brockhoff_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/1komma2ser_brockhoff_noisy.tar.gz|noisyData]]|[[https://hal.inria.fr/inria-00502431/document|cmp1komma2]] [[https://hal.inria.fr/inria-00502432/document|cmp1komma2Noisy]]|
-|37|1komma4|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1komma4_brockhoff_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/1komma4_brockhoff_noisy.tar.gz|noisyData]]|[[https://hal.inria.fr/inria-00502434/document|cmp1komma4serNoisy]] [[http://dx.doi.org/10.1145/1830761.1830780|doi]]\\ the other three papers are not linked to at the moment|
-|38|1komma4mir|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1komma4mir_brockhoff_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/1komma4mir_brockhoff_noisy.tar.gz|noisyData]]| [[http://sci2s.ugr.es/eamhco/pdfs/contributionsGECCO10/p1559-auger.pdf|cmp1komma4And1komma4mirser]] [[http://sci2s.ugr.es/eamhco/pdfs/contributionsGECCO10/p1583-auger.pdf|cmp1komma4And1komma4mirserNoisy]]|
-|39|1komma4mirser|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1komma4mirser_brockhoff_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/1komma4mirser_brockhoff_noisy.tar.gz|noisyData]]|[[http://sci2s.ugr.es/eamhco/pdfs/contributionsGECCO10/p1617-auger.pdf|PDFnoiseless]] [[http://sci2s.ugr.es/eamhco/pdfs/contributionsGECCO10/p1625-auger.pdf|PDFnoisy]] [[http://sci2s.ugr.es/eamhco/pdfs/contributionsGECCO10/p1559-auger.pdf|cmp1komma4And1komma4mir]] [[http://sci2s.ugr.es/eamhco/pdfs/contributionsGECCO10/p1583-auger.pdf|cmp1komma4And1komma4mirNoisy]]|
-|40|1komma4ser|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1komma4ser_brockhoff_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/1komma4ser_brockhoff_noisy.tar.gz|noisyData]]|[[https://hal.inria.fr/inria-00502433/document|cmp1komma4]] [[https://hal.inria.fr/inria-00502434/document|cmp1komma4Noisy]] [[http://dx.doi.org/10.1145/1830761.1830780|doi]]|
-|41|1plus1|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1plus1_brockhoff_noiseless.tar.gz|noiselessData]]|n/a|[[https://hal.inria.fr/inria-00502430/document|cmp1plus2mirser]]|
-|42|1plus2mirser|2010|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/1plus2mirser_brockhoff_noiseless.tar.gz|noiselessData]]|n/a|[[https://hal.inria.fr/inria-00502430/document|cmp1plus1]]|
-|43|ABC|2010|El-Abd|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/ABC_elabd_noiseless.tar.gz|noiselessData]]|n/a|[[http://dx.doi.org/10.1145/1830761.1830794|doi]] |
-|44|AVGNEWUOA\\ :!: algname still NEWUOA :!:|2010|Ros|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/AVGNEWUOA_ros_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/AVGNEWUOA_ros_noisy.tar.gz|noisyData]]| mentioned in 2009 paper, data set submitted in 2009, but data presented only in 2010\\ [[https://hal.inria.fr/inria-00473776/document|cmpNEWUOAFULLNEWUOnoiseless]]|
-|45|CMAEGS|2010|Finck and Beyer|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/CMAEGS_finck_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/CMAEGS_finck_noisy.tar.gz|noisyData]]|[[https://www.researchgate.net/profile/Steffen_Finck/publication/220740259_Benchmarking_CMA-EGS_on_the_BBOB_2010_noiseless_function_testbed/links/09e4150e5889c7141e000000.pdf|PDFnoiseless]] [[http://dx.doi.org/10.1145/1830761.1830784|DOInoisy]]|
-|46|DE-AUC|2010|Fialho et al.|:?:|n/a|data only|
-|47|DE-F-AUC|2010|Fialho et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/DE-F-AUC_fialho_noiseless.tar.gz|noiselessData]]|n/a|[[https://hal.inria.fr/inria-00494535v2/document|cmpPM-AdapSS-DE]]|
-|48|DE-F-SUM|2010|Fialho et al.|:?:|n/a|data only|
-|49|DE-SUM|2010|Fialho et al.|:?:|n/a|data only|
-|50|DEstRand1Bin|2010|Fialho et al.|:?:|n/a|data only|
-|51|DEstRand2Bin|2010|Fialho et al.|:?:|n/a|data only|
-|52|DEstRandToBest2Bin|2010|Fialho et al.|:?:|n/a|data only|
-|53|DEstTargetToRand1Bin|2010|Fialho et al.|:?:|n/a|data only|
-|54|DEuniform|2010|Fialho et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/DEuniform_fialho_noiseless.tar.gz|noiselessData]]|n/a|[[https://hal.inria.fr/inria-00494538/document|cmpPM-AdapSS-DE]]|
-|55|IPOP-ACTCMA-ES|2010|Hansen and Ros|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/IPOP-ACTCMA-ES_ros_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/IPOP-ACTCMA-ES_ros_noisy.tar.gz|noisyData]]|[[https://www.lri.fr/~hansen/ws1p32-hansen.pdf|cmpIPOP-CMA-ESNoiseless]]\\ [[https://www.lri.fr/~hansen/ws1p33-hansen.pdf|cmpIPOP-CMA-ESNoisy]]|
-|56|IPOP-CMA-ES|2010|Hansen and Ros|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/IPOP-CMA-ES_ros_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/IPOP-CMA-ES_ros_noisy.tar.gz|noisyData]]|[[https://www.lri.fr/~hansen/ws1p32-hansen.pdf|cmpIPOP-ACTCMA-ESNoiseless]]\\ [[https://www.lri.fr/~hansen/ws1p33-hansen.pdf|cmpIPOP-ACTCMA-ESNoisy]]\\ [[https://hal.inria.fr/inria-00473777/document|cmpBIPOP-CMA-ESNoiseless]]\\ [[https://hal.inria.fr/inria-00473778/document|cmpBIPOP-CMA-ESNoisy]]|
-|57|MOS|2010|LaTorre et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/MOS_torre_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/MOS_torre_noisy.tar.gz|noisyData]]|[[http://oa.upm.es/7689/2/INVE_MEM_2010_84733.pdf|PDFnoiseless]] [[http://oa.upm.es/7735/2/INVE_MEM_2010_84760.pdf|PDFnoisy]]|
-|58|NBC-CMA|2010|Preuss|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/NBC-CMA_preuss_noiseless.tar.gz|noiselessData]]|n/a|[[http://dx.doi.org/10.1145/1830761.1830793|doi]]|
-|59|NEWUOA|2010|Hansen and Ros|n/a|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/NEWUOA_ros_noisy.tar.gz|noisyData]]|[[https://hal.inria.fr/inria-00473776/document|PDF]]\\ noiseless data under #24 (2009)|
-|60|PM-AdapSS-DE|2010|Fialho et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/PM-AdapSS-DE_fialho_noiseless.tar.gz|noiselessData]]|n/a|[[https://hal.inria.fr/inria-00494538/document|cmpUniformDE]] [[https://hal.inria.fr/inria-00494535v2/document|cmpDE-F-AUC]]|
-|61|RCGA|2010|Tran and Jin|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/RCGA_tran_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/RCGA_tran_noisy.tar.gz|noisyData]]|[[http://dx.doi.org/10.1145/1830761.1830797|doi noiseless]] [[http://dx.doi.org/10.1145/1830761.1830796|doi noisy]]|
-|62|SPSA|2010|Finck and Beyer|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/SPSA_finck_noiseless.tar.gz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2010/SPSA_finck_noisy.tar.gz|noisyData]]|[[https://www.researchgate.net/profile/Steffen_Finck/publication/220743445_Benchmarking_SPSA_on_BBOB-2010_noiseless_function_testbed/links/09e4150e5889bc24a6000000.pdf|PDFnoiseless]] [[https://www.researchgate.net/profile/Steffen_Finck/publication/220740542_Benchmarking_SPSA_on_BBOB-2010_noisy_function_testbed/links/09e4150e5889c4a807000000.pdf|PDFnoisy]]|
-|63|oPOEMS|2010|Kubalík|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/oPOEMS_kubalic_noiseless.tar.gz|noiselessData]]|n/a|[[http://dx.doi.org/10.1145/1830761.1830774|doi cmppPOEMS]]|
-|64|pPOEMS|2010|Kubalík|[[http://coco.gforge.inria.fr/data-archive/bbob/2010/pPOEMS_kubalic_noiseless.tar.gz|noiselessData]]|n/a|[[http://dx.doi.org/10.1145/1830761.1830774|doi cmpoPOEMS]]|
-|65|ACOR|2012|Liao et al|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/ACOR_liao_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p159.pdf|PDF]]|
-|66|BIPOPaCMA|2012|Loshchilov et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/BIPOPaCMA_loshchilov_noiseless.tgz|noiselessData]]|n/a|[[http://coco.lri.fr/BBOB2012-papers/loshchilov_p269.pdf|cmpNIPOPaCMA-BIPOPaCMA-NBIPOPaCM-IPOPaCMA]]|
-|67|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/loshchilov_BBOB2012_noiseless_BIPOPsaACM.tgz|BIPOPsaACM]]|2012|Loshchilov et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/BIPOPsaACM_loshchilov_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p175.pdf|cmpIPOPsaACM]]|
-|68|CMA|2012|Brockhoff et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/CMA_brockhoff_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p297.pdf|cmpCMAaAndCMAm]]|
-|69|CMAa|2012|Brockhoff et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/CMAa_brockhoff_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p277.pdf|cmpCMAmaAndIPOP-ACTCMA-ES]]\\ [[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p297.pdf|cmpCMAandCMAm]]|
-|70|CMAm|2012|Brockhoff et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/CMAm_brockhoff_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p297.pdf|cmpCMAandCMAa]]|
-|71|CMAma|2012|Brockhoff et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/CMAma_brockhoff_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p277.pdf|cmpCMAaAndIPOP-ACTCMA-ES]]\\ [[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p285.pdf|cmpCMAmah]]|
-|72|CMAmah|2012|Brockhoff et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/CMAmah_brockhoff_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p285.pdf|cmpCMAma]] [[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p291.pdf|cmpCMAmh]]|
-|73|CMAmh|2012|Brockhoff et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/CMAmh_brockhoff_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p291.pdf|cmpCMAmah]]|
-|74|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/posik_BBOB2012_CMAES_code_v1.zip|CMAES]]|2012|Pošík and Klemš|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/CMAES_posik_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p189.pdf|cmpDEandDEAEandJADE]]|
-|75|DBRCGA|2012|Chuang and Chen|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/DBRCGA_chuang_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p167.pdf|PDF]]|
-|76|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/posik_BBOB2012_DE_code_v1.zip|DE]]|2012|Pošík and Klemš|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/DE_posik_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p189.pdf|cmpDEAEandJADEandCMAES]]|
-|77|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/posik_BBOB2012_DEAE_code_v1.zip|DEAE]]|2012|Pošík and Klemš|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/DEAE_posik_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p189.pdf|cmpDEandJADEandCMAES]]|
-|78|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/posik_BBOB2012_DEb_code_v1.zip|DEb]]|2012|Pošík and Klemš|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/DEb_posik_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p197.pdf|cmpDEctpbAndDE-F-AUCAndJADEbANDJADEctpb]]|
-|79|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/posik_BBOB2012_DEctpb_code_v1.zip|DEctpb]]|2012|Pošík and Klemš|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/DEctpb_posik_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p197.pdf|cmpDEbAndDE-F-AUCAndJADEbANDJADEctpb]]|
-|80|DE-AUTO|2012|Voglis et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/DE-AUTO_voglis_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p245.pdf|PDF]]|
-|81|DE-BFGS|2012|Voglis et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/DE-BFGS_voglis_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p245.pdf|PDF]] [[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p253.pdf|cmpPSO-BFGS]]|
-|82|DE-ROLL|2012|Voglis et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/DE-ROLL_voglis_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p245.pdf|PDF]]|
-|83|DE-SIMPLEX|2012|Voglis et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/DE-SIMPLEX_voglis_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p245.pdf|PDF]]|
-|84|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/loshchilov_BBOB2012_noiseless_IPOPsaACM.tgz|IPOPsaACM]]|2012|Loshchilov et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/IPOPsaACM_loshchilov_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2012/IPOPsaACM_loshchilov_noisy.tgz|noisyData]]|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p175.pdf|cmpBIPOPsaACM]]\\ [[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p261.pdf|cmpIPOP-ACTCMA-ESNoisy]]|
-|85|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/posik_BBOB2012_JADE_code_v1.zip|JADE]]|2012|Pošík and Klemš|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/JADE_posik_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p189.pdf|cmpDEandDEAEandCMAES]]|
-|86|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/posik_BBOB2012_JADEb_code_v1.zip|JADEb]]|2012|Pošík and Klemš|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/JADEb_posik_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p197.pdf|cmpDEbAndDEctpbAndDE-F-AUCAndJADEctpb]]|
-|87|[[http://coco.gforge.inria.fr/BBOB2012sourcecodes/posik_BBOB2012_JADEctpb_code_v1.zip|JADEctpb]]|2012|Pošík and Klemš|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/JADEctpb_posik_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p197.pdf|cmpDEbAndDEctpbAndDE-F-AUCAndJADEb]]|
-|88|MVDE|2012|Veloso de Melo|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/MVDE_melo_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p183.pdf|PDF]]|
-|89|NBIPOPaCMA|2012|Loshchilov et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/NBIPOPaCMA_loshchilov_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p269.pdf|cmpNIPOPaCMA]]|
-|90|NIPOPaCMA|2012|Loshchilov et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/NIPOPaCMA_loshchilov_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p269.pdf|cmpNBIPOPaCMA]]|
-|91|PSO-BFGS|2012|Voglis et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/PSO-BFGS_voglis_noiseless.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p253.pdf|cmpDE-BFGS]]|
-|92|SNES|2012|Schaul|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/SNES_schaul_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2012/SNES_schaul_noisy.tgz|noisyData]]|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p205.pdf|PDF]]|
-|93|xNES|2012|Schaul|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/xNES_schaul_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2012/xNES_schaul_noisy.tgz|noisyData]]|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p213.pdf|PDF]] [[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p221.pdf|cmpxNESas]]|
-|94|xNESas|2012|Schaul|[[http://coco.gforge.inria.fr/data-archive/bbob/2012/xNESas_schaul_noiseless.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2012/xNESas_schaul_noisy.tgz|noisyData]]|[[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p229.pdf|PDF]] [[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p221.pdf|cmpxNES]]\\ [[https://www.lri.fr/~hansen/proceedings/2012/GECCO/companion/p237.pdf|cmpBIPOP-CMA-ES]]|
-|95|[[http://coco.gforge.inria.fr/BBOB2013sourcecodes/loshchilov_BBOB2013_noiseless_BIPOPsaACM-k.tgz|BIPOP-saACM-k]]|2013|Loshchilov et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/BIPOP-saACM-k_loshchilov_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0306-loshchilov.pdf|cmpLoshchilov}}|
-|96|[[http://coco.gforge.inria.fr/BBOB2013sourcecodes/loshchilov_BBOB2013_noiseless_BIPOP-aCMA-STEP.tgz|BIPOP-aCMA-STEP]]|2013|Loshchilov et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/BIPOP-aCMA-STEP_loshchilov_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0306-loshchilov.pdf|cmpLoshchilov}}|
-|97|CGA-grid16|2013|Holtschulte and Moses|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/CGA-grid16_holtschulte_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0309-holtschulte.pdf|cmpHoltschulte}}|
-|98|CGA-grid100|2013|Holtschulte and Moses|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/CGA-grid100_holtschulte_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0309-holtschulte.pdf|cmpHoltschulte}}|
-|99|CGA-ring16|2013|Holtschulte and Moses|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/CGA-ring16_holtschulte_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0309-holtschulte.pdf|cmpHoltschulte}}|
-|100|CGA-ring100|2013|Holtschulte and Moses|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/CGA-ring100_holtschulte_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0309-holtschulte.pdf|cmpHoltschulte}}|
-|101|CMAES_Hutter|2013|Hutter et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/CMAES_Hutter_hutter_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0311-hutter.pdf|cmpHutter}}|
-|102|DE_Pal|2013|Pàl|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/DE_Pal_pal_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0302-pal.pdf|cmpPalBenchmarking}}|
-|103|fmincon|2013|Pàl|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/fmincon_pal_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0303-pal.pdf|cmpPalComparison}}|
-|104|fminunc|2013|Pàl|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/fminunc_pal_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0303-pal.pdf|cmpPalComparison}}|
-|105|GA-100|2013|Holtschulte and Moses|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/GA-100_holtschulte_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0309-holtschulte.pdf|cmpHoltschulte}}|
-|106|[[http://coco.gforge.inria.fr/BBOB2013sourcecodes/loshchilov_BBOB2013_noiseless_HCMA.tgz|HCMA]]|2013|Loshchilov et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/HCMA_loshchilov_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0306-loshchilov.pdf|cmpLoshchilov}}|
-|107|HILL|2013|Holtschulte and Moses|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/HILL_holtschulte_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0309-holtschulte.pdf|cmpHoltschulte}}|
-|108|HMLSL|2013|Pàl|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/HMLSL_pal_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0302-pal.pdf|cmpPalBenchmarking}}|
-|109|IP|2013|Liao and Stützle|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/IP_liao_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0305-liao.pdf|cmpLiaoTesting}} {{pdf2013:w0304-liao.pdf|cmpLiaoBounding}}|
-|110|IP-10DDr|2013|Liao and Stützle|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/IP-10DDr_liao_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0304-liao.pdf|cmpLiaoBounding}}|
-|111|IP-500|2013|Liao and Stützle|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/IP-500_liao_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0304-liao.pdf|cmpLiaoBounding}}|
-|112|IPOP400D|2013|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/IPOP400D_auger_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0313-auger.pdf|Auger}}|
-|113|lmm-CMA-ES|2013|Auger et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/lmm-CMA-ES_auger_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0313-auger.pdf|Auger}}|
-|114|MEMPSODE|2013|Voglis|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/MEMPSODE_voglis_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0301-voglis.pdf|Voglis}}|
-|115|MLSL|2013|Pàl|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/MLSL_pal_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0302-pal.pdf|cmpPalBenchmarking}}|
-|116|OQNLP|2013|Pàl|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/OQNLP_pal_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0303-pal.pdf|cmpPalComparison}}|
-|117|[[http://coco.gforge.inria.fr/BBOB2013sourcecodes/tran_BBOB2013_noiseless_P-DCN.tar.gz|P-DCN]]|2013|Tran et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/P-DCN_tran_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0312-tran.pdf|cmpTran}}|
-|118|[[http://coco.gforge.inria.fr/BBOB2013sourcecodes/tran_BBOB2013_noiseless_P-zero.tar.gz|P-zero]]|2013|Tran et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/P-zero_tran_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0312-tran.pdf|cmpTran}}|
-|119|PRCGA|2013|Sawyerr et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/PRCGA_sawyerr_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0308-sawyerr.pdf|Sawyerr}}|
-|120|simplex|2013|Pàl|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/simplex_pal_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0303-pal.pdf|cmpPalComparison}}|
-|121|SMAC-BBOB|2013|Hutter et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/SMAC-BBOB_hutter_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0311-hutter.pdf|cmpHutter}}|
-|122|tany|2013|Liao and Stützle|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/tany_liao_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0305-liao.pdf|cmpLiaoTesting}}|
-|123|texp|2013|Liao and Stützle|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/texp_liao_noiseless.tgz|noiselessData]]\\ :!: BBOB2010 instances|n/a|{{pdf2013:w0305-liao.pdf|cmpLiaoTesting}}|
-|124|[[http://coco.gforge.inria.fr/BBOB2013sourcecodes/tran_BBOB2013_noiseless_U-DCN.tar.gz|U-DCN]]|2013|Tran et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/U-DCN_tran_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0312-tran.pdf|cmpTran}}|
-|125|[[http://coco.gforge.inria.fr/BBOB2013sourcecodes/tran_BBOB2013_noiseless_U-zero.tar.gz|U-zero]]|2013|Tran et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2013/U-zero_tran_noiseless.tgz|noiselessData]]|n/a|{{pdf2013:w0312-tran.pdf|cmpTran}}|
-|126| MATSuMoToDefault-50D|2015|Brockhoff|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-CEC/MATSUMOTO-Brockhoff-noiseless.tgz|noiselessData]]|n/a|{{:pdf2015:03-cec2015-brockhoff.pdf|CEC paper}}|
-|127| R-DE-10e2      |2015|Tanabe and Fukunaga|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-CEC/R-DE-10e2-Tanabe-noiseless.tgz|noiselessData]]|n/a|{{:pdf2015:02-cec2015-tanabe.pdf|CEC paper}}|
-|128| R-DE-10e5      |2015|Tanabe and Fukunaga|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-CEC/R-DE-10e5-Tanabe-noiseless.tgz|noiselessData]]|n/a|{{:pdf2015:02-cec2015-tanabe.pdf|CEC paper}}|
-|129| R-SHADE-10e2   |2015|Tanabe and Fukunaga|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-CEC/R-SHADE-10e2-Tanabe-noiseless.tgz|noiselessData]]|n/a|{{:pdf2015:02-cec2015-tanabe.pdf|CEC paper}}|
-|130| R-SHADE-10e5   |2015|Tanabe and Fukunaga|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-CEC/R-SHADE-10e5-Tanabe-noiseless.tgz|noiselessData]]|n/a|{{:pdf2015:02-cec2015-tanabe.pdf|CEC paper}}|
-|131| RL-SHADE-10e2  |2015|Tanabe and Fukunaga|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-CEC/RL-SHADE-10e2-Tanabe-noiseless.tgz|noiselessData]]|n/a|{{:pdf2015:02-cec2015-tanabe.pdf|CEC paper}}|
-|132| RL-SHADE-10e5  |2015|Tanabe and Fukunaga|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-CEC/RL-SHADE-10e5-Tanabe-noiseless.tgz|noiselessData]]|n/a|{{:pdf2015:02-cec2015-tanabe.pdf|CEC paper}}|
-|133| SOO            |2015|Derbel and Preux|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-CEC/SOO-Derbel-noiseless.tgz|noiselessData]]|n/a|[[http://www.grappa.univ-lille3.fr/~ppreux/papiers/cec2015.accepted.pdf|CEC paper]]|
-|134| BSif           |2015|Pošík and Baudiš|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/BSif.tgz|noiselessData]]|n/a|[[http://pasky.or.cz/sci/dimsel.pdf|GECCO paper]]|
-|135| BSifeg         |2015|Pošík and Baudiš|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/BSifeg.tgz|noiselessData]]|n/a|[[http://pasky.or.cz/sci/dimsel.pdf|GECCO paper]]|
-|136| BSqi           |2015|Pošík and Baudiš|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/BSqi.tgz|noiselessData]]|n/a|[[http://pasky.or.cz/sci/dimsel.pdf|GECCO paper]]
-|137| BSrr           |2015|Pošík and Baudiš|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/BSrr.tgz|noiselessData]]|n/a|[[http://pasky.or.cz/sci/dimsel.pdf|GECCO paper]]|
-|138| [[http://coco.gforge.inria.fr/BBOB2015sourcecodes/cma.py|CMA-CSA]] |2015|Atamna|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/CMA-CSA.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~atamna/atamna_BBOB_15.pdf|GECCO paper]]|
-|139| [[http://coco.gforge.inria.fr/BBOB2015sourcecodes/cma.py|CMA-MSR]] |2015|Atamna|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/CMA-MSR.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~atamna/atamna_BBOB_15.pdf|GECCO paper]]|
-|140| [[http://coco.gforge.inria.fr/BBOB2015sourcecodes/cma.py|CMA-TPA]] |2015|Atamna|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/CMA-TPA.tgz|noiselessData]]|n/a|[[https://www.lri.fr/~atamna/atamna_BBOB_15.pdf|GECCO paper]]|
-|141| GP1-CMAES      |2015|Bajer et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/GP1-CMAES.tgz|noiselessData]]|n/a|[[http://dx.doi.org/10.1145/2739482.2768468|doi]]|
-|142| GP5-CMAES      |2015|Bajer et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/GP5-CMAES.tgz|noiselessData]]|n/a|[[http://dx.doi.org/10.1145/2739482.2768468|doi]]|
-|143| IPOPCMAv3p61   |2015|Bajer et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/IPOPCMAv3p61.tgz|noiselessData]]|n/a|[[http://dx.doi.org/10.1145/2739482.2768468|doi]]|
-|144| LHD-10xDefault-MATSuMoTo|2015|Brockhoff et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/LHD-10xDefault-MATSuMoTo.tgz|noiselessData]]|n/a|[[https://hal.inria.fr/hal-01161504/document|GECCO paper]]|
-|145| LHD-2xDefault-MATSuMoTo |2015|Brockhoff et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/LHD-2xDefault-MATSuMoTo.tgz|noiselessData]]|n/a|[[https://hal.inria.fr/hal-01161504/document|GECCO paper]]|
-|146| RAND-2xDefault-MATSuMoTo|2015|Brockhoff et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/RAND-2xDefault-MATSuMoTo.tgz|noiselessData]]|n/a|[[https://hal.inria.fr/hal-01161504/document|GECCO paper]]|
-|147| RF1-CMAES      |2015|Bajer et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/RF1-CMAES.tgz|noiselessData]]|n/a|[[http://dx.doi.org/10.1145/2739482.2768468|doi]]|
-|148| RF5-CMAES      |2015|Bajer et al.|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/RF5-CMAES.tgz|noiselessData]]|n/a|[[http://dx.doi.org/10.1145/2739482.2768468|doi]]|
-|149| Sif            |2015|Pošík and Baudiš|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/Sif.tgz|noiselessData]]|n/a|[[http://pasky.or.cz/sci/dimsel.pdf|GECCO paper]]|
-|150| Sifeg          |2015|Pošík and Baudiš|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/Sifeg.tgz|noiselessData]]|n/a|[[http://pasky.or.cz/sci/dimsel.pdf|GECCO paper]]|
-|151| Srr            |2015|Pošík and Baudiš|[[http://coco.gforge.inria.fr/data-archive/bbob/2015-GECCO/Srr.tgz|noiselessData]]|n/a|[[http://pasky.or.cz
-/sci/dimsel.pdf|GECCO paper]]|
-|152| PSAaLmC        |2016|Nishida and Akimoto|[[http://coco.gforge.inria.fr/data-archive/bbob/2016/PSAaLmC.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2016/PSAaLmC-noisy.tgz|noisyData]]|[[https://www.researchgate.net/profile/Youhei_Akimoto/publication/302359371_Evaluating_the_Population_Size_Adaptation_Mechanism_for_CMA-ES_on_the_BBOB_Noisy_Testbed/links/572fd0ab08ae744151904d91.pdf|GECCO paper]]|
-|153| PSAaLmD        |2016|Nishida and Akimoto|[[http://coco.gforge.inria.fr/data-archive/bbob/2016/PSAaLmD.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2016/PSAaLmD-noisy.tgz|noisyData]]|[[https://www.researchgate.net/profile/Youhei_Akimoto/publication/302359371_Evaluating_the_Population_Size_Adaptation_Mechanism_for_CMA-ES_on_the_BBOB_Noisy_Testbed/links/572fd0ab08ae744151904d91.pdf|GECCO paper]]|
-|154| PSAaSmC        |2016|Nishida and Akimoto|[[http://coco.gforge.inria.fr/data-archive/bbob/2016/PSAaSmC.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archive/bbob-noisy/2016/PSAaSmC-noisy.tgz|noisyData]]|[[https://www.researchgate.net/profile/Youhei_Akimoto/publication/302359371_Evaluating_the_Population_Size_Adaptation_Mechanism_for_CMA-ES_on_the_BBOB_Noisy_Testbed/links/572fd0ab08ae744151904d91.pdf|GECCO paper]]|
-|155| PSAaSmD        |2016|Nishida and Akimoto|[[http://coco.gforge.inria.fr/data-archive/bbob/2016/PSAaSmD.tgz|noiselessData]]|[[http://coco.gforge.inria.fr/data-archives/bbob-noisy/2016/PSAaSmD-noisy.tgz|noisyData]]|[[https://www.researchgate.net/profile/Youhei_Akimoto/publication/302359371_Evaluating_the_Population_Size_Adaptation_Mechanism_for_CMA-ES_on_the_BBOB_Noisy_Testbed/links/572fd0ab08ae744151904d91.pdf|GECCO paper]]|
-</sortable>
algorithms.1494841970.txt.gz · Last modified: 2017/05/15 11:52 by brockho
CC Attribution-Noncommercial-Share Alike 3.0 Unported
Valid CSS Driven by DokuWiki Recent changes RSS feed Valid XHTML 1.0
