Differences
bbob-2010-downloads [2010/03/05 16:21]
rros
bbob-2010-downloads [2011/10/06 16:32] (current)
vhm
Line 1: Line 1:
 ~~NOCACHE~~ ~~NOCACHE~~
-This is the BBOB 2010 download page.+This is the BBOB 2010 download page. The most recent BBOB version can be found [[http://coco.gforge.inria.fr/doku.php?id=downloads|here]].
-[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobexp10.0.tar.gz|BBOB 2010 (Version 10.03MB)]] is all that is needed to run the benchmarking experiments and prepare a single-algorithm workshop paper (comparing to data obtained during BBOB-2009). Additional post-processing code to prepare a workshop paper that compares two or more benchmarked algorithms will be available soon+[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobexp10.2.tar.gz|BBOB 2010 (Version 10.23.6MB)]] is all that is needed to run the benchmarking experimentsprepare a single-algorithm workshop paper (comparing to data obtained during BBOB-2009) or compare two or more benchmarked algorithms.
-[[http://coco.lri.fr/BBOB-downloads/download10.0/bboball10.0.tar.gz|BBOB-2010 tarball (34MB)]] is the full tarball with all technical documentations and presentation of the functions. It contains all files listed below.+[[http://coco.lri.fr/BBOB-downloads/download10.2/bboball10.2.tar.gz|BBOB-2010 tarball (34MB)]] is the full tarball with all technical documentations and presentation of the functions. It contains all files listed below.
   * CODE:   * CODE:
-    *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobmatlab.tar.gz|tar]] code in Matlab/Octave  +    *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobmatlab.tar.gz|tar]] code in Matlab/Octave
-    *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobc.tar.gz|tar]] code in C  +    *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobc.tar.gz|tar]] code in C
-    *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobjava.tar.gz|tar]] code in Java +    *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobcpp.tar.gz|tar]] code in C++ (still in BETA)
-    *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobpproc.tar.gz|tar]] post-processing in Python (2.5MB)+    *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobjava.tar.gz|tar]] code in Java
 +    *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobpproc.tar.gz|tar]] post-processing in Python (3.1MB)
   * DOCS:   * DOCS:
-      *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobdocexperiment.pdf|pdf]] description of experimental procedure   +      *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobdocexperiment.pdf|pdf]] description of experimental procedure
-      *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobdocfunctions.pdf|pdf]] (13MB) noiseless functions documentation with figures +      *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobdocfunctions.pdf|pdf]] (13MB) noiseless functions documentation with figures
-      *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobdocfunctionsdef.pdf|pdf]] noiseless functions documentation, version without figures +      *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobdocfunctionsdef.pdf|pdf]] noiseless functions documentation, version without figures
-      *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobdocnoisyfunctions.pdf|pdf]] (20MB) noisy function documentation with figures       +      *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobdocnoisyfunctions.pdf|pdf]] (20MB) noisy function documentation with figures
-      *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobdocnoisyfunctionsdef.pdf|pdf]] noisy function documentation, version without figures   +      *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobdocnoisyfunctionsdef.pdf|pdf]] noisy function documentation, version without figures
-      *[[http://coco.lri.fr/BBOB-downloads/download10.0/bbobdocsoftware.pdf|pdf]] software user documentation  +      *[[http://coco.lri.fr/BBOB-downloads/download10.2/bbobdocsoftware.pdf|pdf]] software user documentation
   * TECHNICAL DOCS:   * TECHNICAL DOCS:
-      *[[http://coco.lri.fr/BBOB-downloads/download10.0/pydoc/bbob_pproc.html|html]] post-processing package documentation+      *[[http://coco.lri.fr/BBOB-downloads/download10.2/pydoc/bbob_pproc.html|html]] post-processing package documentation
 +BUGS for older versions:
 +  * **Bugs in version 10.1**:
 +     * Post-processing: the significance test in Figure 1 of the comparison template is wrongly computed.
 +     * Post-processing: running the runcomp2 routine with input parameters path0/samefoldername and path1/samefoldername processed only one data set.
 +     * Java code: the attributes of JNIfgeneric.Params were not modifiable from outside the javabbob package.
 +  * **Bug in version 10.0**:
 +     * ECDF figures: data of the entries in 2009 were represented in a wrong manner, making them appear better than they actually were.
bbob-2010-downloads.1267802468.txt.gz · Last modified: 2010/03/05 16:21 by rros
CC Attribution-Noncommercial-Share Alike 3.0 Unported
Valid CSS Driven by DokuWiki Recent changes RSS feed Valid XHTML 1.0
