bbob-2013-program [2013/06/03 11:14] brockho |
bbob-2013-program [2013/07/12 12:41] (current) brockho |
Line 1: | Line 1: | ||
- | == preliminary schedule == | + | ===== BBOB-2013 - Saturday, July 6th 2013, GECCO 2013, Amsterdam ===== |
- | Please note that the schedule below is tentative and might be subject to changes | + | === Preliminary Schedule === |
+ | (Please note that the schedule below is tentative and might be subject to changes) | ||
+ | ==Location: Room 04A00== | ||
^ 8:30-10:20 (surrogates and linkage) ^^ | ^ 8:30-10:20 (surrogates and linkage) ^^ | ||
- | | 08:30 - 09:00 | Nikolaus Hansen: **Introduction to Blackbox Optimization Benchmarking** | | + | | 08:30 - 09:00 | Nikolaus Hansen:\\ **Introduction to Blackbox Optimization Benchmarking** | |
- | | 09:00 - 09:35 | Ilya Loshchilov: **BI-population CMA-ES Algorithms with Surrogate Models and Line Searches** | | + | | 09:00 - 09:35 | Ilya Loshchilov:\\ **BI-population CMA-ES Algorithms with Surrogate Models\\ and Line Searches** {{slides2013:SlidesIlya.pdf|Slides}}| |
- | | 09:35 - 10:10 | László Pál: **Benchmarking a Multi Level Single Linkage Algorithm with Improved Global and Local Phases** | | + | | 09:35 - 10:10 | László Pál:\\ **Benchmarking a Multi Level Single Linkage Algorithm\\ with Improved Global and Local Phases** {{slides2013:mlsl.pdf|Slides}}| |
- | | 10:10 - 10:20 | Nikolaus Hansen: **Session Wrap-up** | | + | | 10:10 - 10:20 | Nikolaus Hansen:\\ **Session Wrap-up** | |
- | ^ 10:40-12:30 (an algorithmic jam-session) ^^^ | + | ^ 10:40-12:30 (an algorithmic jam-session) ^^ |
- | | 10:40 - 10:45 | Dimo Brockhoff | "Session Introduction" | | + | | 10:40 - 10:45 | Dimo Brockhoff:\\ **Session Introduction** {{slides2013:session2-bbob-turbo-intro.pdf|Slides}}| |
- | | 10:45 - 11:05 | Dimo Brockhoff | "Multiobjectivization with NSGA-II on the Noiseless BBOB Testbed" | | + | | 10:45 - 11:05 | Dimo Brockhoff:\\ **Multiobjectivization with NSGA-II on the Noiseless BBOB\\ Testbed** {{slides2013:session2-multiobjectivization.pdf|Slides}}| |
- | | 11:05 - 11:30 | Costas Voglis | "Adapt-MEMPSODE: A Memetic Algorithm with Adaptive Selection of Local Searches" | | + | | 11:05 - 11:30 | Costas Voglis:\\ **Adapt-MEMPSODE: A Memetic Algorithm with Adaptive\\ Selection of Local Searches** {{slides2013:voglis_bbob_present.pdf|Slides}}| |
- | | 11:30 - 11:55 | Babatunde Sawyerr | "Benchmarking Projection-Based Real Coded Genetic Algorithm on BBOB-2013 Noiseless Function Testbed" | | + | | 11:30 - 11:55 | Babatunde Sawyerr:\\ **Benchmarking Projection-Based Real Coded Genetic\\ Algorithm on BBOB-2013 Noiseless Function Testbed** {{slides2013:BBOB-2013 conference-prcga.pdf|Slides}}| |
- | | 11:55 - 12:20 | Neal Holtschulte | "Benchmarking Cellular Genetic Algorithms on the BBOB Noiseless Testbed" | | + | | 11:55 - 12:20 | Neal Holtschulte:\\ **Benchmarking Cellular Genetic Algorithms on the BBOB\\ Noiseless Testbed** {{slides2013:cellularGA_2013_NealHoltschulte.pdf|Slides}}| |
- | | 12:20 - 12:30 | Dimo Brockhoff | "Session Wrap-up" | | + | | 12:20 - 12:30 | Dimo Brockhoff:\\ **Session Wrap-up** {{slides2013:session2-wrapup.pdf|Slides}}| |
- | ^ 14:00-15:50 (expensive optimization) ^^^ | + | ^ 14:00-15:50 (expensive optimization) ^^ |
- | | 14:00 - 14:05 | Anne Auger | "Session Introduction" | | + | | 14:00 - 14:05 | Anne Auger:\\ **Session Introduction** | |
- | | 14:05 - 14:35 | Anne Auger | "Benchmarking within the Expensive BBOB Setting: a Case-Study on the local meta-model CMA-ES" | | + | | 14:05 - 14:35 | Anne Auger:\\ **Benchmarking within the Expensive BBOB Setting: a\\ Case-Study on the local meta-model CMA-ES** | |
- | | 14:35 - 15:00 | Frank Hutter | "An evaluation of sequential model-based optimization for expensive blackbox functions" | | + | | 14:35 - 15:00 | Holger Hoos:\\ **An evaluation of sequential model-based optimization\\ for expensive blackbox functions** | |
- | | 15:00 - 15:25 | Thomas Stützle | "Bounding the population size of IPOP-CMA-ES on the Noiseless BBOB Testbed" | | + | | 15:00 - 15:25 | Thomas Stützle:\\ **Bounding the population size of IPOP-CMA-ES on the\\ Noiseless BBOB Testbed** {{slides2013:00-bbob2013slides.pdf|Slides}}| |
- | | 15:25 - 15:40 | Nikolaus Hansen | "A Short Hands-On Tutorial of BBOB/COCO" | | + | | 15:25 - 15:40 | Nikolaus Hansen:\\ **A Short Hands-On Tutorial of BBOB/COCO** | |
- | | 15:40 - 15:50 | Nikolaus Hansen | "Session Wrap-up" | | + | | 15:40 - 15:50 | Nikolaus Hansen:\\ **Session Wrap-up** | |
- | ^ 16:10-18:00 (wrap-up + panel) ^^^ | + | ^ 16:10-18:00 (wrap-up + panel) ^^ |
- | | 16:10 - 16:25 | Nikolaus Hansen | "A Brief Overview of Blackbox Optimization Benchmarking" | | + | | 16:10 - 16:25 | Nikolaus Hansen:\\ **A Brief Overview of Blackbox Optimization Benchmarking** | |
- | | 16:25 - 16:40 | Nikolaus Hansen | "Wrap-up of the BBOB-2013 Results" | | + | | 16:25 - 16:40 | Nikolaus Hansen:\\ **Wrap-up of the BBOB-2013 Results** | |
- | | 16:40 - 18:00 | Mike Preuss (moderator) | panel discussion, panelists to be announced later | | + | | 16:40 - 18:00 | Mike Preuss (moderator):\\ **panel discussion**, panelists to be announced | |
