Differences
bbob-2013-program [2013/07/09 11:56]
brockho
bbob-2013-program [2013/07/12 12:41] (current)
brockho
Line 7: Line 7:
 ^ 8:30-10:20 (surrogates and linkage) ^^ ^ 8:30-10:20 (surrogates and linkage) ^^
 |  08:30 - 09:00  | Nikolaus Hansen:\\ **Introduction to Blackbox Optimization Benchmarking** | |  08:30 - 09:00  | Nikolaus Hansen:\\ **Introduction to Blackbox Optimization Benchmarking** |
-|  09:00 - 09:35  | Ilya Loshchilov:\\ **BI-population CMA-ES Algorithms with Surrogate Models\\ and Line Searches** | +|  09:00 - 09:35  | Ilya Loshchilov:\\ **BI-population CMA-ES Algorithms with Surrogate Models\\ and Line Searches** {{slides2013:SlidesIlya.pdf|Slides}}
-|  09:35 - 10:10  | László Pál:\\ **Benchmarking a Multi Level Single Linkage Algorithm\\ with Improved Global and Local Phases** |+|  09:35 - 10:10  | László Pál:\\ **Benchmarking a Multi Level Single Linkage Algorithm\\ with Improved Global and Local Phases** {{slides2013:mlsl.pdf|Slides}}|
 |  10:10 - 10:20  | Nikolaus Hansen:\\ **Session Wrap-up** | |  10:10 - 10:20  | Nikolaus Hansen:\\ **Session Wrap-up** |
Line 15: Line 15:
 | 10:40 - 10:45 | Dimo Brockhoff:\\ **Session Introduction** {{slides2013:session2-bbob-turbo-intro.pdf|Slides}}| | 10:40 - 10:45 | Dimo Brockhoff:\\ **Session Introduction** {{slides2013:session2-bbob-turbo-intro.pdf|Slides}}|
 | 10:45 - 11:05 | Dimo Brockhoff:\\ **Multiobjectivization with NSGA-II on the Noiseless BBOB\\ Testbed** {{slides2013:session2-multiobjectivization.pdf|Slides}}| | 10:45 - 11:05 | Dimo Brockhoff:\\ **Multiobjectivization with NSGA-II on the Noiseless BBOB\\ Testbed** {{slides2013:session2-multiobjectivization.pdf|Slides}}|
-| 11:05 - 11:30 | Costas Voglis:\\ **Adapt-MEMPSODE: A Memetic Algorithm with Adaptive\\ Selection of Local Searches** | +| 11:05 - 11:30 | Costas Voglis:\\ **Adapt-MEMPSODE: A Memetic Algorithm with Adaptive\\ Selection of Local Searches** {{slides2013:voglis_bbob_present.pdf|Slides}}
-| 11:30 - 11:55 | Babatunde Sawyerr:\\ **Benchmarking Projection-Based Real Coded Genetic\\ Algorithm on BBOB-2013 Noiseless Function Testbed** |+| 11:30 - 11:55 | Babatunde Sawyerr:\\ **Benchmarking Projection-Based Real Coded Genetic\\ Algorithm on BBOB-2013 Noiseless Function Testbed** {{slides2013:BBOB-2013 conference-prcga.pdf|Slides}}|
 | 11:55 - 12:20 | Neal Holtschulte:\\ **Benchmarking Cellular Genetic Algorithms on the BBOB\\ Noiseless Testbed** {{slides2013:cellularGA_2013_NealHoltschulte.pdf|Slides}}| | 11:55 - 12:20 | Neal Holtschulte:\\ **Benchmarking Cellular Genetic Algorithms on the BBOB\\ Noiseless Testbed** {{slides2013:cellularGA_2013_NealHoltschulte.pdf|Slides}}|
 | 12:20 - 12:30 | Dimo Brockhoff:\\ **Session Wrap-up** {{slides2013:session2-wrapup.pdf|Slides}}| | 12:20 - 12:30 | Dimo Brockhoff:\\ **Session Wrap-up** {{slides2013:session2-wrapup.pdf|Slides}}|
Line 25: Line 25:
 | 14:05 - 14:35 | Anne Auger:\\ **Benchmarking within the Expensive BBOB Setting: a\\ Case-Study on the local meta-model CMA-ES** | | 14:05 - 14:35 | Anne Auger:\\ **Benchmarking within the Expensive BBOB Setting: a\\ Case-Study on the local meta-model CMA-ES** |
 | 14:35 - 15:00 | Holger Hoos:\\ **An evaluation of sequential model-based optimization\\ for expensive blackbox functions** | | 14:35 - 15:00 | Holger Hoos:\\ **An evaluation of sequential model-based optimization\\ for expensive blackbox functions** |
-| 15:00 - 15:25 | Thomas Stützle:\\ **Bounding the population size of IPOP-CMA-ES on the\\ Noiseless BBOB Testbed** |+| 15:00 - 15:25 | Thomas Stützle:\\ **Bounding the population size of IPOP-CMA-ES on the\\ Noiseless BBOB Testbed** {{slides2013:00-bbob2013slides.pdf|Slides}}|
 | 15:25 - 15:40 | Nikolaus Hansen:\\ **A Short Hands-On Tutorial of BBOB/COCO** | | 15:25 - 15:40 | Nikolaus Hansen:\\ **A Short Hands-On Tutorial of BBOB/COCO** |
 | 15:40 - 15:50 | Nikolaus Hansen:\\ **Session Wrap-up** | | 15:40 - 15:50 | Nikolaus Hansen:\\ **Session Wrap-up** |
bbob-2013-program.1373363769.txt.gz · Last modified: 2013/07/09 11:56 by brockho
CC Attribution-Noncommercial-Share Alike 3.0 Unported
Valid CSS Driven by DokuWiki Recent changes RSS feed Valid XHTML 1.0
